Guest 240ZPompanoFlorida Posted September 7, 2006 Share Posted September 7, 2006 I have just bought a 72 240z , headers, cam, rebuilt engine , some head work 30,000 miles ago. Had to put on Rebuilt calipers, turned rotors, new pads front / rear, new actuators rear, new brake fluid and bleed system. Brakes are stock. When bought car you could push brake pedal about 40% before feeling brakes start to engage. AFTER ALL THE NEW BRAKES put on and bleed the pedal still goes about 30% before you feel any pressure against foot . The brakes work great if you press harder just seems that they take to much pedal pressure to make work ? IS THIS NORMAL TO THIS MODEL CAR ? Car has a master cylinder with vacumm attached. Pic attached. Cam is mild and has plenty of vacumm. Thank you much for any help or suggestions this is my first post and FIRST Z.. much work ahead of me. regards JOHN Quote Link to comment Share on other sites More sharing options...
RedNeckZ Posted September 7, 2006 Share Posted September 7, 2006 Have you adjusted the rod going from the foot assemble to the master cyclinder yet? You can lay on the floor under the steering wheel and adjust it with a few wrenchs. All you have to do is loosen it up and turn the bar out until you reach the point you want. It may take you a few times to get it right. But it does work pretty good. Good Luck, Rich. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted September 7, 2006 Share Posted September 7, 2006 Just don't take ALL of the slack out. You need 1/8" or so, otherwise the brakes will stick on. Quote Link to comment Share on other sites More sharing options...
Guest 240ZPompanoFlorida Posted September 7, 2006 Share Posted September 7, 2006 You guys are great.. I will do it tomorrow see how that helps... dont think its the retention disc in power booster but guess thats my next try ? Quote Link to comment Share on other sites More sharing options...
