strength differences in L28 rods???
LT280z
Shot peening is a surface treatment that compresses the surface of a part and cold works it to increase fatigue resistance, reduce stress risers, and increase durability. I personally haven't seen any surface finish differnces between rods from a turbo F54 block and rods from a NA N42 block but that doesn't mean much. Depending on the shot peening process, it might be difficult or impossible to tell the difference between a peened part and a part that had be abrasively clenaed or polished. Also, its very common to polish a part after its shot peened.
Two cents.
I have some experience with shot peening for what its worth.
When I have had to have a fabricated part shot peened or a structural repair area shot peened, the process is fairly straight forward but very specific.
In short the shot peen process useing flap strap or free ball is a carefully calculated process with respect to duration. And that duration is extensive. The part is whapped for so long that it is difficult to tell the difference. You dont see any "dents". Its very smooth. And yes polish is usually part of the process. Age the part and it is impossible to tell the difference. A surface hardness test will show the diff but, in the case of a rod, the hardness tester will defeat the benefits that shot peening provides...stress free surface....by creating a diviot in the part.
Going to need more factory data on this one. It's gotta be there somewhere!;)
http://carfiche.com/fiche009/s130/2/c08.gif
Carfiche only appears to list one conrod for both L28E and L28ET.
Dave
Yep, sure enough. They wouldnt need to use a different rod for the low boost turbo cars, when 600 HP is done on stock rods, and they knew about that one before 1981. Same rods on ALL L28's
Guest Andrew240
I have rods from both. I also have a Rockwell tester at work I can use. I'll be pulling the rods out of my turbo block sometime this week. I'll test a non-turbo L28 rod, and a turbo L28 rod, and report the hardness of each.
Will that help?
Just a kind of FYI - it might be a good idea to stay away from a headgasket (other then stock) until you have a forged bottom end. Sure having a nice HG on there is great, and prevents from blowing a stock one...
But in the case of detonation, where do you want that force from predetonation going... through the HG? Or through the pistons, rings, and rods?
