Sudden powerloss
Guest SupraG
Hi everyone. I was just driving to work, and I felt a sudden powerloss in my bone stock (engine wise) 260z. I just bought this car last week and the stock 2.6 liter was rebuild 3500 miles ago. I am puzzled why I experienced a sudden powerloss and was wondering if any of you have experienced the same thing. Thanks.
I would check the basics first fuel filter, pump flow, spark plugs, ignition wires (especially the one from the coil to distributor) and all grounds.
Bone stock 260Z? Does that mean it has the stock Hitachi carbs? If it has the stock carbs instead of the SU's (or another upgrade) then that is one concern. I've heard of powerloss with a distributor not putting out enough current if the bushings are worn.
my problem was solved when i checked the cables connected to the distributer and spark plugs. a coupe that connect to the ignition coil and distributer were slightly popped out, and i just plugged them in, also my air filter was outrageously old and dirty. i replaced it with a k&n filter and so far its runnnig really well and accelerates fine.
thanks for the tips, i was way off thinknig it was a fuel problem.
