383 240z Posted March 5, 2001 Share Posted March 5, 2001 Great choice on your motor the zz4 motor is internaly balanced if your using the JTR mounts mind the clearance on the steering gear I think the max size is 7.25" please use an installer for the new balancer Do not beat it on with a hammer!! (I've seen to many good motors destroyed by this) you will not need to rebalance your motor after the swap (only 383 strokers and 400 are external balanced) ------------------ rx7260z@yahoo.com Speed Power Performance& Style. What else is there? Quote Link to comment Share on other sites More sharing options...
John Scott Posted March 6, 2001 Share Posted March 6, 2001 Rob, didn't you use the smaller 6.25 Fluidamper on your ZZ4? JS Quote Link to comment Share on other sites More sharing options...
Guest kc6wfs Posted March 6, 2001 Share Posted March 6, 2001 Hi Adam, On my ZZ3 I got rid of the 8" ballencer and bought from PAW there 6 1/4" chrome "Super Saver" liquid damper PAW-FB350 No problems with it at all. Dave ------------------ www.geocities.com/kc6wfs/240z.html www.NitroPhotos.com Quote Link to comment Share on other sites More sharing options...
DavyZ Posted March 6, 2001 Share Posted March 6, 2001 Adam, get a harmonic damper install/removal kit from Summit Racing--they have one somewhere in their catalog in addition to low price dampers. Great choice in an engine. It's sooo good, it'll drive you MAD! ...sorry, couldn't resist! David Quote Link to comment Share on other sites More sharing options...
madmanadam Posted March 6, 2001 Author Share Posted March 6, 2001 Hello, all This might have been asked before, I did a search did not find what I was looking for. I just bought a ZZ4 Crate engine. Can I just change out the damper or do I need to balance? Any help would be great. What is this engine internal or external balanced? Thanks again Adam Soon to be on the road again 2yrs waiting and changing. Quote Link to comment Share on other sites More sharing options...
madmanadam Posted March 6, 2001 Author Share Posted March 6, 2001 Thanks, picked up the motor last night. $3419 total from Scoggin-Dickey Parts Center in Tx. Shipped to Wa. Not bad. The engine even came with plugs. I just cant wait to hear it run. Another Question will my block hugger (2001) headers still work with this engine? Soon go zoom and fun in the sun in shacky washington. Thanks again will order a puller and damper Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 7, 2001 Share Posted March 7, 2001 Your blockhugger headers will bolt up, but unless they are specifically designed to fit GM corvette "D" shaped ports,they will probably block the top of the "D" shaped port and restrict exhaust flow. You may be able to grind off enough metal to match the port shape, but you would be better off buying a new set from Sanderson or Heddman-they both make block hugger headers for "D" port heads. ------------------ Tony 1972 240Z w/ZZ430/T56/GTO body kit Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted March 7, 2001 Share Posted March 7, 2001 The balancer that came stock on my ZZ engine clears with no problems. I think the ports on the aluminum heads on this engine are only a tenth of an inch higher than other Chevy heads, so restrictions, if any, will be minimal. Quote Link to comment Share on other sites More sharing options...
madmanadam Posted March 8, 2001 Author Share Posted March 8, 2001 Are you sure the balancer will fit? I measured and it is 8". JTR 7.25 is max I thought. Thanks Quote Link to comment Share on other sites More sharing options...
