Epoxy as a stiffener in rear crossmember mounts?
I know this might me a bad idea, but I was wondering if I could use some epoxy filler in my rear crossmember mounts as well as in the rear differential mount to stiffen up the stock rubber mounts, to make it more of a solid mounting system. I know that Jeff P has used custom made aluminum bushings for his project 280zxt, and I've also seen modified Z31 polyuretane bushing used. Would the epoxy be strong enought for the job or become too brittle over time to make this a viable alternative? If this is at all possible what type of epoxy should I consider for the job? This would be for an 83 s130.
I currently have the rear crossmember striped and slotted for camber and toe adjustment and the while I'm at it bug has reared it sometimes expensive head. Thanks in advance for your time and opinions/ critique on my ideas. Renn
