roninjiro Posted September 22, 2006 Share Posted September 22, 2006 my butterfly shaft and the bushings are worn and causing a vaccum leak, anyone know where to get some replacements b/s ztherapy? Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 22, 2006 Share Posted September 22, 2006 There are plenty of British Car Sites that will offer the same services, but why go cross-manufacturer when ZThreapy knows our setups and what works? Why the resistance to ZT? Quote Link to comment Share on other sites More sharing options...
roninjiro Posted September 22, 2006 Author Share Posted September 22, 2006 z therapy wont sell the bushings and shafts separate from their carb kits. so i must find elsewhere Quote Link to comment Share on other sites More sharing options...
zeiss150 Posted September 22, 2006 Share Posted September 22, 2006 the quick fix is to throw a little grease on the outside of the throttle shafts. A nice thick bearing grease will plug up the throttle shaft leak. Its a temporary fix but it works. I called my local carborator shop and asked them if they could replace the bearings in my SU's and they said, sure. give it a shot... whats the worst that could happen:) Matt Quote Link to comment Share on other sites More sharing options...
Silent Posted September 22, 2006 Share Posted September 22, 2006 set the needles rich to compensate for the additional air leaking in. Quote Link to comment Share on other sites More sharing options...
roninjiro Posted September 22, 2006 Author Share Posted September 22, 2006 new problem guys. i had spare su's and changed out the shafts and very little play, the old shafts were showing brass badly, the ones i put in still had the plating on it. no shaft leakage. but i have the problem of my firewall carb running lean. i did lift the piston and it kills the motor, the other side (radiator carb) stays close to idle. so i adjust the mixture thing on the bottom to richen, nothing, some gain but not much. i think what the problem is; is the float adjustment. when i turned my fuel pump off and let it starve itself i took the float covers off to see what i had. my firewall carb still had fuel in it and my radiator carb was bone dry. floats people???? im leaning toward that idea but need some input from you guys. also note: new sm needles new nozzles new float cutoff valves Quote Link to comment Share on other sites More sharing options...
roninjiro Posted September 23, 2006 Author Share Posted September 23, 2006 take a look at the floats does anyone see a problem like i do? like possibly the tops are from different carbs Quote Link to comment Share on other sites More sharing options...
roninjiro Posted September 24, 2006 Author Share Posted September 24, 2006 ok, fixed carb problem (used 70 float tops), now all i have is a timing problem to fix, and fine tune of carbs. timing i can do well, but fine tuning of carbs i need help. does anyone know how to tune su carbs for z's properly b/c i pulled the spark plugs and plugs 1,2,5,6 are fouled and plugs 3,4 are fine. Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted September 25, 2006 Share Posted September 25, 2006 http://classiczcars.com/forums/showthread.php?t=23101&highlight=su Look at post #6. It is not applicable regarding different fuel bowl tops but does provide the basic info required when tuning twin SU's. It should get you real close if nothing else is wrong. One more thing, if the plugs are really fouled clean or replace brfore tuning. Blip the throttle occasionally during tuning to clear the plugs of carbon. Quote Link to comment Share on other sites More sharing options...
