big-phil Posted September 26, 2006 Author Share Posted September 26, 2006 Phil just found this thread. I believe you can use a 2.75" to 2.5" adapter for the outlet on the turbo. This is a new holset hy with the 90 turn on the compressor side correct? Also I have a 4" k&n filter for the turbo if you need it. Yes the newer 05 hy, how much do you want for the K&N? I will need one once I get MSnS. Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted September 27, 2006 Share Posted September 27, 2006 yes, you need to use a 2.75" - 2.5" (or 3" if you have 3" ic piping) silicone adapter off the turbo outlet for ic piping. The turbo is appox 2.5" inner diamter, but the outside dimeter is larger where you will need to a 2.75" to fit around it. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 27, 2006 Share Posted September 27, 2006 isnt that only for FWD? RWD shouldnt be loosing that much... i don't know about the difference with front or rear drive. I'm sure there is one but, I don't know the numbers for it. I just stick to the 15% number. Quote Link to comment Share on other sites More sharing options...
