3" intercooler pipe to big? with Holset Hy35??
big-phil
Phil just found this thread. I believe you can use a 2.75" to 2.5" adapter for the outlet on the turbo. This is a new holset hy with the 90 turn on the compressor side correct? Also I have a 4" k&n filter for the turbo if you need it.
Yes the newer 05 hy, how much do you want for the K&N? I will need one once I get MSnS.
Guest 280ZForce
yes, you need to use a 2.75" - 2.5" (or 3" if you have 3" ic piping) silicone adapter off the turbo outlet for ic piping. The turbo is appox 2.5" inner diamter, but the outside dimeter is larger where you will need to a 2.75" to fit around it.
