VG33TT Posted September 26, 2006 Share Posted September 26, 2006 Motor was running great last night. I go to start it today and it suddnely looses compression. It sounded like the timming belt broke and I can here the pistons hiting the valves. I pulled the timming covers off and its still in perfict time, timming belt is new. This motor has only 30k on it. Then I pulled the valve covers off and all of the intake valves are stuck open. So what the heck happend to caus this? I am going to get another moter this weekend but I just dont understand what happend to this one. I never even got to drive it, I just got it running last night. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted September 26, 2006 Share Posted September 26, 2006 Is it me or am I not seeing oil anywhere on the valve train like I should be? Quote Link to comment Share on other sites More sharing options...
jap tin Posted September 26, 2006 Share Posted September 26, 2006 good eye dr hunt. looks like the valves hung in the guides. Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted September 26, 2006 Share Posted September 26, 2006 Ok, just had to check, your not oiling the top end for some reason, the guides need some oil to function, yours obviously didn't get any. But it's too late now. That motor probably has other problems now too, but it still will make a great boat anchor! Oh, and ditch the worthless fram filters and get a real filter would you! Quote Link to comment Share on other sites More sharing options...
VG33TT Posted September 27, 2006 Author Share Posted September 27, 2006 There is plenty of oil in there. Its just hard to se in that pic. If the cylinder head was starved of oil I would of herd lots of clicking and chatering from the hydraulic lifters. What could caus the valve guids to not get oil? Do you think bad gas could of gummed them up causing them to stick open? Quote Link to comment Share on other sites More sharing options...
MONGO510 Posted September 27, 2006 Share Posted September 27, 2006 What is the crap on your Valves? Quote Link to comment Share on other sites More sharing options...
bubbleguinea Posted September 27, 2006 Share Posted September 27, 2006 it looks like there is a chunk taken out of the valve stem?!?!?! Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted September 28, 2006 Share Posted September 28, 2006 Somehow none of that looks very good. You say the engine was sitting for a long period of time? If so then I'd imagine the valve could have been stuck in the phosphorous/bronze guides, but not all that likely. Hard to say without seeing it first hand. Quote Link to comment Share on other sites More sharing options...
VG33TT Posted September 28, 2006 Author Share Posted September 28, 2006 Look at the gas I drained out of the tank, it is almost black. I think old gas is to blame for the valves sticking. I am going to have the tank cleaned and blow out the lines for the new motor. Quote Link to comment Share on other sites More sharing options...
Guest Jason84NA-T Posted October 3, 2006 Share Posted October 3, 2006 How is the tension on the belt? My guess is it slipped if the tension was too low. I've seen VG's with the intake valves stuck open. When the piston hits them they bend at the thinner part of the stem right near the guide and then can't close at all. Quote Link to comment Share on other sites More sharing options...
