good "stand alone" pcm edit? please help!
I'm not entirely sure of what you're asking, but I'll give it a shot. In general the stock PCM program will work fine for a stock engine. I believe the one thing that my PCM gets from my T56 is the Vehicle Speed Sensor (VSS), does the T5 have a VSS or can you put one on it? The other issue you may have is with the Vehicle Anti-Theft Sytem (VATS), you may have to have this programmed out if you con't use the donor ignition.
Did you win a reprogram of your PCM or the software to reprogram your own PCM?
