S&W halo bar
660Z
I would venture a guess to say that cutting the halo and sectioning it to fit is a no-no. I haven't seen the rulebook, but it seems like a very bad idea in general to cut and reweld any of the rollbar tubes in the middle.
You might be able to pull them closer together at the ends and weld them to the main hoop just the way they are. I'm thinking a cumalong hooked around each end of the tube might do it. I know when I welded in my main hoop I had to spread it about an inch and I used a portapowr and it didn't take much effort at all to spread those suckers.
If that didn't work it sounds like a call to S&W would be the next move. Apparently they bent in the wrong place or not enough on your kit.
