Most cost efficient way to lower overall gear ratio
v80z
im in the same boat as you 4 speed with a 3.90 also.
the cheaper way is to try to stuff the tallest tire you can fit back there.
im going to go with a 26 inch tall tire.
but then again you can probably find a 3.54 r200 cheaper than a set of tires.
v80z... So you bought a T56? I was going to replace my TH350 with a 200R4 but a T56 would be great. I talked to a local mechanic who said swapping to a standard isn't that difficult or pricey regarding labor. I may change my mind. That 6-speed with .5 OD would be N-I-C-E...
