Solid mounting Rear Diff?
JustinOlson
One issue that has been much discussed (and debated) is the suggestion of either all solid, or all flex mounted attachments. Solid mounting of either the front or rear (but not both) will very likely result in the solid mount tearing away or fatique failure at some point. Solid mounting only one end of the differential still allows the other end (the flexible mount) to move, focusing all this stress onto a solid mount that was not designed to be flexed. Eventually, the constant bending will result in failure. By solid mounting both ends, you eliminate all movement, which results in a durable and long lasting mounting system.
