F54 Block, Flat Top Pistons above Deck - Which Gasket to Use?
240zip
I have a L28 F54 block that's been bored .5mm over in which I installed flat top pistons. I've searched the forum and it appears this set-up results in the pistons protruding above the deck .021". I measured my #1 and #6 pistons at TDC and they were indeed .020" above the deck. I have a NAPA (Victor) head gasket on order. I believe it's a 1.6mm thickness gasket.
The head being used is an E31 head. As far as I can tell, it was never shaved, but has been completely rebuilt. I'm using ARP bolts (main, rod, head).
Any recommendations on gaskets? The set-up is what I'd term a mild street engine. Headers, Triple 42DCOE-8 Webers, moderate cam, etc.
A stock L28 has a deck height of 0.030", so with less height (0.020"), you should be fine with a stock gasket (1.6mm). Also, a stock L24 with the E31 head has a deck height of 0.080", so even with the E31 head, you are OK.
