Acronym Definitions?
I keep reading suspension threads from the past trying to learn more, but I find myself chin deep in acronyms that I dont know the definition to. You guys are as bad as engineers when it comes to talking about suspension. I would like people to define the acronyms used when talking about Z car suspension. Pictures of these parts would be great to help define everything as well. Thanks for you help. I hope I'm not the only person confused by all of these acronyms.
Regards,
Justin
Here are the few I can think of right now:
LCA - lower control arm (redundant because there is no upper control arm)
TC rod - tension-compression rod
RCAs - Roll center adjusters (aka Bumpsteer spacers)
Poly Bushings - polyurethane bushings
Is there any one specific acronym that you don't understand?
from the thread linked below,
ARB - anti-roll bar
CG - center of gravity
RS - roll steer
RC - roll center
RCH - roll center height
RA - roll axis
DRC - dynamic roll center
IC - instant center
FT - full throttle
PT - part throttle
WOT - wide open throttle
NRA - neutral roll axis
NSP - neutral steer point
LLT - lateral load transfer
LLTD - lateral load transfer distribution
SLA - short long arm suspension
DR - damping ratio
SR - tire slip ratio
UO - understeer/oversteer
