Alri Posted November 10, 2006 Share Posted November 10, 2006 The turn signals on my Z don't work. The hazard light are working tough. Now, the Z has a 5 terminal flasher, what current are those terminals receiving + or -? does the flasher send + or - to the turn signals? does the turn signal lever send + or - current to the flasher? I have spend hours trying to fix it and I just can't. Please if someone knows answer those question specifically, thanks. Quote Link to comment Share on other sites More sharing options...
hotimport Posted November 10, 2006 Share Posted November 10, 2006 I have fixed mine on the 75 Z and i had to pull the whole steering off it. In my case there was just a lose connection between the assemblly. It a pain in the a$$ to fix. Also it could be the whole assemblly that you might need to replase or might be a fuse. Quote Link to comment Share on other sites More sharing options...
Bartman Posted November 10, 2006 Share Posted November 10, 2006 Alri said: The turn signals on my Z don't work. The hazard light are working tough. Now, the Z has a 5 terminal flasher, what current are those terminals receiving + or -? does the flasher send + or - to the turn signals? does the turn signal lever send + or - current to the flasher?I have spend hours trying to fix it and I just can't. Please if someone knows answer those question specifically, thanks. I think the answer to your specific question is that the turn signal lever sends positive to the flasher and the flasher sends positive to the signals. I don't recall my turn signal flasher having 5 terminals...but maybe it does. I seem to recall the turn signal flasher not being the same as the hazard flasher. Quote Link to comment Share on other sites More sharing options...
hotimport Posted November 10, 2006 Share Posted November 10, 2006 hazard lights have a diffrent fuse then the left and right turnsignals. Quote Link to comment Share on other sites More sharing options...
Alri Posted November 10, 2006 Author Share Posted November 10, 2006 I ended up hooking the left and right turn signals to two switches in the center console. The hazard lights switch turns the left side signal, and the rear defroster switch turns the right one on. I can easily reach both of them. that was the fastest way to get my turn signals to work because, like it was said in an above post, I could have a bigger problem. Quote Link to comment Share on other sites More sharing options...
