bryan01 Posted November 15, 2006 Share Posted November 15, 2006 i know other people have had this problem, but i couldnt find it in a quick search. does anyone know the size to the return line hole that's in the rb20 oil pan's? i'm pretty sure it's an m16, and after searching locally for a while i found one that was much too long, but at this point i dont care, but it was still the wrong threading. the m16 i have looks pretty corse (i think the pitch is 2mm), is it just a fine (what would this pitch be?) m16? or is it some standard pipe thread size? where could i get ahold of a fine threaded m16? what does everyone else do w/ the hole that's in the pan since the rb25 drains to the block? weld over it? (which i almost did last night but didnt want to remove the oil pan.) Quote Link to comment Share on other sites More sharing options...
bryan01 Posted November 15, 2006 Author Share Posted November 15, 2006 well i just found a place (guy) with every bolt ever made in every length and pitch (more importantely m16, 1.5mm pitch, 35mm long), so i'll try it out tonight when i get home. Quote Link to comment Share on other sites More sharing options...
hotimport Posted November 15, 2006 Share Posted November 15, 2006 What motor are you doing this on RB25 or RB26??? Quote Link to comment Share on other sites More sharing options...
bryan01 Posted November 16, 2006 Author Share Posted November 16, 2006 What motor are you doing this on RB25 or RB26??? rb25det ... but it's ok, the m16 w/ a 1.5 mm pitch worked. that's a big ass bolt ... Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted November 16, 2006 Share Posted November 16, 2006 Are you talking about the place where the oil temperature sensor goes? I just simply ran a oil temperature sensor, they are really cheap and good insurance. It is the same part number as the Z31's oil temp sensor. Quote Link to comment Share on other sites More sharing options...
Mike Rowe Posted November 17, 2006 Share Posted November 17, 2006 Are you talking about the place where the oil temperature sensor goes? I just simply ran a oil temperature sensor, they are really cheap and good insurance. It is the same part number as the Z31's oil temp sensor. I have put a 240Z water temp sensor in that sump as it fits and am using a second 240Z water temp guage as my oil temp guage above my oil pressure guage (adapted original instruments) See my website regards Quote Link to comment Share on other sites More sharing options...
bryan01 Posted November 17, 2006 Author Share Posted November 17, 2006 now there's some usefull information. i didnt know a sensor went there. but yeah, i plugged it w/ a bolt. thanks for the info thou, once i get it running and driveable i'll look into puting a temp sensor there. Quote Link to comment Share on other sites More sharing options...
