rb20 oil pan return line hole size?
bryan01
i know other people have had this problem, but i couldnt find it in a quick search. does anyone know the size to the return line hole that's in the rb20 oil pan's? i'm pretty sure it's an m16, and after searching locally for a while i found one that was much too long, but at this point i dont care, but it was still the wrong threading. the m16 i have looks pretty corse (i think the pitch is 2mm), is it just a fine (what would this pitch be?) m16? or is it some standard pipe thread size? where could i get ahold of a fine threaded m16?
what does everyone else do w/ the hole that's in the pan since the rb25 drains to the block? weld over it? (which i almost did last night but didnt want to remove the oil pan.)
  Racinjitter said:
Are you talking about the place where the oil temperature sensor goes? I just simply ran a oil temperature sensor, they are really cheap and good insurance. It is the same part number as the Z31's oil temp sensor.
I have put a 240Z water temp sensor in that sump as it fits and am using a second 240Z water temp guage as my oil temp guage above my oil pressure guage (adapted original instruments)
See my website
regards
