T56 Rebuild
SSflyer
My trans started locking in 4th gear and after seeing the cost of rebuilt units I'm thinking about doing it myself. There's a complete parts kit on EBAY for about 1/4 the cost of a rebuilt, but before I spend the dough I would like to know if this is something a reasonable mechanic can do at home? Anyone here ever had any experience?
I tried to dissassemble my T56 using a puller from Rockland Gear.I wasn`t` succesful and was told that T56`s can be real bears to take apart without the correct press and hydraulic pullers. But, I will post a link to Rockland Gear and this.http://para.noid.org/~lj/T56/T56.htm
http://www.rsgear.com/kits.html
http://www.ls2.com/forums/showthread.php?s=&threadid=1877
I have rebuilt about 10 T56 trannys in my garage. It is not that hard.
D&D performance ( http://www.ddperformance.com/ ) sells bearing and synchro kits. They also sell a T56 repair manual. The "locking" in 4th is not that uncommon. There are 3 shift detent clips in the synchro that can bend and break off. If one breaks off it can jam up the transmission and lock it in gear. I have seen several, including one of mine, do the same thing. The clips are about $2 each, but the whole tranny has to come apart to get to them. As far as specialty tools, I have part of a Kent-Moore puller that I used threaded rod and a balancer puller piece to make work and a small press with several different sized bearing puller attachments.
Picture of the modified Kent Moore puller http://jodyc.fbody.com/bobs-tranny/kent%20moore%20tool%20and%20puller.jpg
Here is a link to the T-56 repair manual .... FREE of charge :-) It's large so it will take some time to download. http://jodyc.fbody.com/T56-manual/T56_service_manual.pdf
Here are a few pics of a trashed T-56! He lost all of his detent clips and the tranny managed to go into 2 gears at once... transmissions don't like that very much...this one was never rebuilt. http://jodyc.fbody.com/Davestranny/
Jody
Great links! I suspect that rebuilding a trans falls into the same 'you can never do that' category as building your own hybrid z car. Well, I did the first, so maybe this can be done too. Thanks for the link to the manual, I'll download that first, since reading is free....
My T-56 was bought used and is a POS. It pops out of 3rd, it is hard to downshift to 2nd and it whines in 5th and 6th. I plan to purchase a rebuilt performance unit from Rockland this winter and do the swap. $1595 plus a core charge. They were recommended to me by a racer that has a 2002 Camaro SS. He swears by them. I think if I took it apart, i would have peices all over my garage for the entire winter. I leave thisngs like this to the experts. You have to know your limitations.
Good Luck.
