Junk Yard R200
Just Jim
I picked up a 3.90 R200 out of a '83 280ZX at Pic a Part yesterday.Is there an easy way to tell prior to installation if it will be noisy or not? The yard also had a 300ZX with a 1989 build date and a finned rear cover on the rear but it was a short nosed R200. I though I found an elusive CLSD R200 but guess not.
The only easy things to check before installing it would be the play in the gears by having someone hold the tires, and those little types of things. If it's pretty tight and you don't hear any grinding you should be ok. I don't know what else you can do without installing it and getting it on the road to get a real feel for it.
