L26 Cam into L28?
geordieggg
Guest d3c0y z3d
Well anyway i was reading this thread the other night and i thought i would check out what sort of cams i had in vairous heads i had lying around the garage.
I have an 05L head from an L20ET and it has a 'D' cam in it and it's not in the list of stock cams that the link pointed to.
Anyone had any experience with these cams?
  • 1 month later...
Well, after all this time, I finally got my A into G and got a cam reground here in NZ.
So what are the general opinions, considering it's (I'm assuming) a stock head? Should make a considerable difference?
The only things I'm concerned about are, on the back of the card, it tells me I must not use a synthetic oil during break-in, and that some synthetic oilsmust never be used with hard welded cams?
Also, is it possible to change the rockers and lash pads (when setting up the valve-train) without removing the cam?
What are the specs on the cam you had ground? Hard for us to say if it will make a difference without knowing that. If it's big enough to make a difference, then it will make a difference. If it is really tiny like a Schneider stage 1 you might not notice any difference at all.
You can swap out the lash pads with the cam in place. What you do is loosen up the adjuster, remove the mousetrap springs, turn the cam so the lobe is away from the rocker, then pry the rocker off to one side and pop it off the ball end.
I put a copy of the cam card on my previous post, if the links not working let me know and I'll try it another way.
Cool, thanks. I'm thinking that, because I'm changing the cam towers as well (for the spray bar) I can get the towers & cam in and lined up so there's no binding, then fit the rockers.
Cam lift 0.305" for intake & exhaust
Valve lift (net) 0.451" for intake & exhaust
Duration @ 0.050" 224 for intake & exhaust
Centreline @ peak lift 105° ATDC for intake, 114° BTDC for exhaust
Now, cam timing @0.050" lift, intake opens 6° BTDC, closes 38° ABDC, exhaust opens 46° BBDC and exhaust closes 2° BTDC.
Hope that all makes sense to someone out there!!
2178_thumb.attach
The only things I'm concerned about are, on the back of the card, it tells me I must not use a synthetic oil during break-in, and that some synthetic oils must never be used with hard welded cams?
Sorry if I come across as sounding pushy, but need to have the car running for the track on Sunday and this is the biggest thing I'm worried about at the moment. Can anyone shed some light on this?
Brilliant, had a go at this last night, even manged to get some of the rockers back in, so myplan should work fine. Thanks for the great info.
  • 1 year later...
