LS2 tach problem
m1noel
Mike,
Have you verified that your tach was working before the swap? This is the only thing I can think off. I didn't go this route because of this reason. For the price of buying the converter and recalibrate the tach I could have bought the autometer gauges and it's a direct hook up. It worked great in my friend's swap. I might do the same on my Ls1 swap soon too. Good luck
Vinh
  VinhZXT said:
Mike,
Vinh
By converter do you mean the speedo converter?
I thought the only thing required to "recalibrate" the tach was to turn one adjustment screw to the end of it's travel. At least that is what the JTR manual says, is it different for LS motors?
Also make sure you have a 280 tach and not a 240 tach, since the 240 units are current activated and, as per the JTR manual, will not work with the more modern tach drives (which I believe are voltage activated).
Yes, the tach was working, and it is a 280 tach. I really wanted to keep the stock guages, just my preferance. The speedo converter works great though and was easy to hook up and calibrate. I just don't know if the tach signal out of the ECM will trigger the tach. Ulises had the same problem with the autometer tach, he had to hook it up to a coil I believe. There has to be a way.... My tach is back at JCI right now. I'll have to see what they say.
Mike
For the autometer tach you have to set it in 4cyl mode. Don't ask me why. If you set it at 8 cyl mode it won't display correctly and it jumps all over the place. I heard from a guy on LS1tech that you can hook up a pull up resistor to eliminate the jumpings of the needle. I didn't do this on my friend's LS1 swap and the tach was OK. I used the tach signal coming from the LS1 Inline Harness so it might be coming from the PCM. Maybe there is something with the LS2.
