510six Posted January 10, 2007 Share Posted January 10, 2007 This is a dattalog of my methanol injection system under boost.The tempurature drops from almost 140 to 74 degrees in an instant, it allowed for 6* more timing under boost with crappy 91 oct pump gas. http://album.hybridz.org/showphoto.php?photo=12629&size=big&cat=500 Quote Link to comment Share on other sites More sharing options...
linluv84 Posted January 10, 2007 Share Posted January 10, 2007 Looks good! I assume that is a profe$$ional setup? Does anybody have any experience with the lower end washer fluid type setups? Quote Link to comment Share on other sites More sharing options...
510six Posted January 10, 2007 Author Share Posted January 10, 2007 I have actually used an old Spearco water/alcohol injection system which consisted of a tank that was pressurised from boost pressure and used a small 40psi pump and a small jet in the intake tract and a Hobbs switch to activate at 7psi.Still worked fine with 12psi of boost with a small T4/T4 turbo and 275rwh.The setup was the brainchild of AEM engineers and tweaking of the AEM EMS by a PRO tuner. Quote Link to comment Share on other sites More sharing options...
Sparky Posted January 10, 2007 Share Posted January 10, 2007 very cool, Im anxious to see what my EGTs do after I convert to E85 next summer. Quote Link to comment Share on other sites More sharing options...
510six Posted January 10, 2007 Author Share Posted January 10, 2007 The dattalog is with 30% methanol as fuel at 7.5 psi of boost.40% methanol will be used at higher boost levels once the boost is increased. Quote Link to comment Share on other sites More sharing options...
gretchen/jason Posted January 14, 2007 Share Posted January 14, 2007 I assume this is with a turbo . Would methanol injection also work with a supercharger ? Jason Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted January 14, 2007 Administrators Share Posted January 14, 2007 Would methanol injection also work with a supercharger ? Yup. Quote Link to comment Share on other sites More sharing options...
