triple weber manifold comparison,runner lgth
s14280zx
I'm building an F-54 block, and a N-47 head for my 79 280zx, and I'm putting triple weber 40mm dcoe's on it. I have a set already, but I've seen on ebay some manifolds have long runners and some have short runners. Are there any advantages between one or the other as far as power? I think mine is a TWM from what I've been told. It seems to have short runners. I appreciate all of your input.
The TWM is a middle length. The Mikunis have very short runners which makes the turns inside the runners more extreme, the Cannon has longer runners, but their castings suck so a lot of cleanup work is necessary to fix them. The TWM is right about where the old Nissan Comp manifold was for length, and is a good starting point. If I were buying another manifold I'd ditch my Cannon for a TWM. Apparently you need to grind or modify that manifold a bit to get the Webers bolted up, so don't be too surprised when that happens.
Thanks for your input. What effect does the runner length have as far as powerband,(low end torque, throttle response, etc.)? Is there a preferred length over others, or not enough difference to worry about? I'm just curious, and I've read a few things about my 240sx ka24de engine that says the long runners on the intake manifold make the engine have lots of low torque, but makes it rev to a lower rpm and has less high end power in return. Would the L28 with carbs be effected similarly by the runner length?
