sfpar Posted January 17, 2007 Share Posted January 17, 2007 Hello all. New Z guy here with a few questions. I have a 1978 280z w/ 82 turbo engine. Ignition, ECU, AFM, injectors are all 1978 z NA. I am intercooled and just running stock boost currently. I have read through the archives and there are many things to check. I have checked nearly all and the car still runs pig rich. I tried to use the turbo injectors but the car would not run at all with them in. I have a plan that may solve the issue and also give me the increase in power at the same time. I am going to swap out the AFM one more time (have one sitting around) and see where that goes. I have purchased the 60mm tb upgrade and will install for more airflow. I doubt seriously that these will be that much of a remedy. My plan, since I want to be able to get to 300hp with bigger injectors, is to go ahead and get the SDS fuel management. I'm thinking that I might be able to lean it out or richen it up through tuning and just forget the old ECU and AFM. I know it's a bit pricey but I need a simple install system since I seem to be the only turbo swap in the Cincinnati, OH area. BTW, I tried talking to some local dyno/performance guys and they have never dealt with Megasquirt at all. Does this seem like a logical approach to get where I'm trying to go? Is there something I may have missed or not tried other than previously mentioned? Thanks very much. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted January 17, 2007 Administrators Share Posted January 17, 2007 I'm thinking that I might be able to lean it out or richen it up through tuning and just forget the old ECU and AFM. Sure could... else they might be out of business I know it's a bit pricey but I need a simple install system since I seem to be the only turbo swap in the Cincinnati, OH area. SDS is not pricey. EFI Technology's 'top-shelf' is $25K... its all relative BTW, I tried talking to some local dyno/performance guys and they have never dealt with Megasquirt at all. Not surprised... also not a disappointment. My opinion?... seriously consider what your local shop's are using. Quote Link to comment Share on other sites More sharing options...
