what Stainless Steel Brake Lines to buy?
i'm doing the vented 4x4 caliper upgrade what Stainless Steel Brake Lines do i need to buy for it? where can i get them? will the ones they sell at msa work?
also can i go from the hard line on the frame rail straight to the caliper or do i need that little piece holding it to the strut?
thanks
If you got the 4x4 swap from MSA it should have included SS brake lines.
I am using the MSA brake lines from that way overpriced dumb 4x4 swap "kit" they have...all it was was was unpainted calipers and SS lines...
With the SS lines you no longer need the short metal tube as the SS lines go right from the frame over to the caliper. Watch out for the mounting angle and make sure it doesn't rub your tire when you turn the wheel all the way.
