alexideways Posted January 17, 2007 Share Posted January 17, 2007 Anybody knows how good/bad is the stock intercooler on an skyline??? Thanks. Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted January 18, 2007 Share Posted January 18, 2007 pretty uselss with anything over 10-12psi, becomes a restricon. Quote Link to comment Share on other sites More sharing options...
alexideways Posted January 18, 2007 Author Share Posted January 18, 2007 But, for a stock RB25, it would do the job or is it at its efficiency limit right off the bat? Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted January 18, 2007 Share Posted January 18, 2007 for a stock one its fun, untill you want more, Stock boost yeah fine. After a bit of thrashing they do start to heat up. Quote Link to comment Share on other sites More sharing options...
alexideways Posted January 18, 2007 Author Share Posted January 18, 2007 Good cause, I found a stock intercooler for $30 on e-bay and was wondering if it'd do the job untill I rais the funds to buy my Greddy style intake and a bigger crossflow intercooler. Quote Link to comment Share on other sites More sharing options...
300zxt Posted January 20, 2007 Share Posted January 20, 2007 Keep in mind that the stock application for that intercooler on a Skyline is a top mount setup, and as stagefumer11 mentioned above is prone to heat soak... Quote Link to comment Share on other sites More sharing options...
alexideways Posted January 20, 2007 Author Share Posted January 20, 2007 What if I mount it in the front????? Quote Link to comment Share on other sites More sharing options...
hotimport Posted January 20, 2007 Share Posted January 20, 2007 Alex, i would probably say that the stock one wouldnt last long because its so small and ultra thin core. You will be better off with a front mount then a side mount size core, its not that its bad or it will overheat it will eventially crap out by leaking air. And since youre buying it used it might off happened allready. It just when it comes down to picking diffrent cores, i would go with something new even if its some chinese crap thats cheap, will give out after a year or so. But at least you will be on safe side. Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted January 21, 2007 Share Posted January 21, 2007 actaully the skyline ones are not top mount. They are a side mount running down the side of the passengers gard. The problem with these factory cores are they are prone to splitting, Ive seen a hell of alot of "factory" used r32/r33's with split intercoolers. Quote Link to comment Share on other sites More sharing options...
alexideways Posted January 21, 2007 Author Share Posted January 21, 2007 Thanks guys,I'll stay away. Quote Link to comment Share on other sites More sharing options...
300zxt Posted January 21, 2007 Share Posted January 21, 2007 I was thinking of the RB20DET with the TMIC, my bad... Quote Link to comment Share on other sites More sharing options...
stagefumer11 Posted January 21, 2007 Share Posted January 21, 2007 you would be thinking of the 200zr z31 rb20det Quote Link to comment Share on other sites More sharing options...
300zxt Posted January 22, 2007 Share Posted January 22, 2007 That and any RB20DET, i.e the R31 Skyline Passage... A friend has 4 of them. Quote Link to comment Share on other sites More sharing options...
