power steering on a 280z??
the rack/pinion design is better than the recirculating ball (power steering ie. PS). I don't advise this because its a lot of fabbing for ultimately what you are going to remove. When the car is traveling the steering becomes lighter. Just have to beef up those arms.
But, there are some on here that have done a power rack/pinion conversion from a Masda MX-5 and WRX IIRC. Which I suggest in doing, if you REALLY want to have power steering.
im going to be getting an s14 fron suspension, and using the power steering rack from that, but then again, im replacing the factory crossmember and suspension links, as well as my front frame rails, so that might not be of any help.
put some muscle into'er!
