I think my vb921 is giving me problems?
big-phil
When I first hooked MSnS up I did not invert the coil signal, and the vb921 got REAL hot several times. Well the other day the car died all of the sudden, then came back on. In megatune you can see that the coil is not getting a signal when this happens, then it came back and Chris (the tunner of the car) drove the dog $h!t out of it, and could not reproduce the problem. I then cleaned up the wiring going to the relay box, and used di-electric grease everywhere.
That was last week, before my latest video. Then today on the way home from work it dies about 3 times on the highway then comes back after about 10sec. I just rechecked all the wiring from the relay box to everything. It all has power where needed. and all wires from the relay box to their perspective destination have good readings and show no breaks.
This makes me think the vb921 is going out. This had me worried, untill I just orderd one from DIYautotune.com for $5.95.
Is there a way to test the vb921?? So I can be sure its out. I searched and came up with nothing.
Thanks all!!!!!!!!!!!!!!!!!!!
What is your dwell set to, and what coil are you using?
If you suspect the VB921, for $5.95 just replace it. An improper dwell over long periods of time can make one fail. Or, the damage could of been done when you had the output not inverted. The device could now be just starting to fail because of damage that was done earlier. Put a new one in so you know what you are working with.
I think the dwell is 6.5, 1.5, and .5 If that does not sound right I can fire up the lap-top and tell you for sure.
