ZXRockie Posted February 5, 2007 Share Posted February 5, 2007 I have a set of 300ZX wheels to pick up from a friend... would they fit in a 260z? does anyone have this set up? Quote Link to comment Share on other sites More sharing options...
DavyZ Posted February 5, 2007 Share Posted February 5, 2007 I have a set of 300ZX wheels to pick up from a friend... would they fit in a 260z? does anyone have this set up? Does your 260Z have a 5 lug conversion? Z32 wheels are 5 lug. Your 260Z is 4 lug if it is still stock. Davy Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted February 5, 2007 Author Share Posted February 5, 2007 Does your 260Z have a 5 lug conversion? Z32 wheels are 5 lug. Your 260Z is 4 lug if it is still stock. Davy well yeah, sorry about that... but it is a 5-lug all around. I need to know if anyone have use z32 in a 5-lugs conversion, if anyone has I need to know the spacer size and tire size. If it work I have a wheel set. Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted February 5, 2007 Share Posted February 5, 2007 The offset is all wrong, the Z32s will not clear a standard spring, tried to put one on the rear of mine to reduce track, will not come close to a fit.(I run a nissan PCD 5 lug) Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted February 6, 2007 Author Share Posted February 6, 2007 The offset is all wrong, the Z32s will not clear a standard spring, tried to put one on the rear of mine to reduce track, will not come close to a fit.(I run a nissan PCD 5 lug) Nissan PCD 5 lug? Thank you for the info. what about the front would they fit with the Z31 hub? Sorry for all the question but I just don't want to spend my time and money into something that won't work. Quote Link to comment Share on other sites More sharing options...
onlydrvsnissan Posted February 6, 2007 Share Posted February 6, 2007 all nissans 5 lug is 114.3x5 Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted February 9, 2007 Share Posted February 9, 2007 I run a set on my car, Z31 hubs in front with a 1/4 inch spacer. Rear is a bit different, 1.50 inch spacer. I have coilovers on my car. There is enough room to run those wheels with a larger spacer in the front with stock springs. I have the 7.5 inch NA wheels all the way around. Doug Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted February 9, 2007 Author Share Posted February 9, 2007 I run a set on my car, Z31 hubs in front with a 1/4 inch spacer. Rear is a bit different, 1.50 inch spacer. I have coilovers on my car. There is enough room to run those wheels with a larger spacer in the front with stock springs. I have the 7.5 inch NA wheels all the way around. Doug I though so, the front should be okay then, thanks for the info. the rear uses to big of a spacer.I would use the Z32 for the front and let see what I find for the rear... Maybe my friends have any low offset wheels sesting around their garage... do you have any pics available? thank you for the spacer information. Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted February 9, 2007 Share Posted February 9, 2007 Here is the only picture I've got around right now. Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted February 9, 2007 Author Share Posted February 9, 2007 Here is the only picture I've got around right now. Thanks brother, very nice ride BTW... my still a monster ... what Tire size can one fit in it? Quote Link to comment Share on other sites More sharing options...
Doug71zt Posted February 9, 2007 Share Posted February 9, 2007 It has 245/50/16 Nitto DR´s on it there. The fronts are 225/50/16, which are a good fit on 7.5 inch rings. Thanks Doug Quote Link to comment Share on other sites More sharing options...
