whyrualive Posted February 11, 2007 Share Posted February 11, 2007 Hi All, My son and I have the dash apart on the 240z and we wanted to recondition the wiring harness once and for all. I checked "How to Restore Your Datsun Z car" with no luck. We searched the threads, but didn't see any related topics. Any ideas on where to find this information? Any suggestions? Your help is appreciated! Guy and Caleb Quote Link to comment Share on other sites More sharing options...
aziza z Posted February 11, 2007 Share Posted February 11, 2007 im redoing the whole harness in my 280z right now as well. I went with a univsal wiring harness thou. ez2 wire (that what im using) or painless(aonther good one). Its a pain in the a:flamedevi:flamedevi but when your done every wire is labeled and color coded. by the way there is a thread on wiring somewhere i believe. Quote Link to comment Share on other sites More sharing options...
vashonz Posted February 11, 2007 Share Posted February 11, 2007 Most people just replace wiring harnesses with painless or similar. The only reason I can see to keep the original would be for a concourse restoration. The issue with the old wiring harnesses is that the insulation gets brittle and cracks. Condensation get inside the wire and corrodes the wire causing higher resistance, poor performance. Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted February 11, 2007 Share Posted February 11, 2007 You can get a new EZWiring harness for $100+ that includes a new fuse boz. Plus side is NO FUSIBLE LINKS. Quote Link to comment Share on other sites More sharing options...
whyrualive Posted February 11, 2007 Author Share Posted February 11, 2007 Buying a replacement seems like a good idea. Do the connectors on the replacements work with the gauges / engine wiring harness? Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted February 11, 2007 Share Posted February 11, 2007 No, you will need to cut, strip, solder, and heatshrink. Quote Link to comment Share on other sites More sharing options...
whyrualive Posted February 11, 2007 Author Share Posted February 11, 2007 That sounds like a lot of work. Any idea how long it will take? Quote Link to comment Share on other sites More sharing options...
sweetleaf Posted February 11, 2007 Share Posted February 11, 2007 It's basicly a complete overhaul, if you want to do it right. As far as I know. No one makes an after market plug in harness. Yes, it's a ton of work but well worth it. Do it once, do it right and be done. How long it takes all depends on you. Quote Link to comment Share on other sites More sharing options...
whyrualive Posted February 11, 2007 Author Share Posted February 11, 2007 Sounds like we should just dive in... Thanks for the advice. How do you clean the connector ends that plug into the existing components? Quote Link to comment Share on other sites More sharing options...
