z ya Posted February 22, 2002 Share Posted February 22, 2002 I finally got the r200 mustache bar to complete my swap. The bars bushings look to be cracked and torn. The r180 bar that I have looks like near new cond. How are they replaced? Large press? They look to be the same size? Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted February 22, 2002 Share Posted February 22, 2002 The easiest thing may actually be to install some polyurethane Energy Suspension bushings. Instead of having to press the outer bushing shell out of the mustache bar, you just remove all the rubber (doesn't take long, just cut it out and use a torch to heat around the bar until you can scrape off every scrap of rubber) and press in the poly bushings with a regular vise. they'll be better in the long run anyway. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted February 22, 2002 Share Posted February 22, 2002 Yup, no press needed. Just torch (propane works just fine) those suckers right out. Hold the flame to it and keep it there. It will start smoking real bad, but keep it there, it will make cleaning out the inside a lot easier. Let it burn, then smush it all out with a screwdriver. Installing poly bushings are probably your best bet. You know, I haven't heard anyone say anything about torching these things out (easiest way to do it), even though the mustache bar is spring steel, and heating it, or drilling into it for the R230 swap, supposedly weakens spring steel. !M! Quote Link to comment Share on other sites More sharing options...
jeromio Posted February 22, 2002 Share Posted February 22, 2002 I don't think the heat from the burning out of the rubber is anywhere near hot enough to cause any tempering of the mustache bar. Not mentioned here, and probably because it's obvious, but Don't remove the bushing sleeves from the mustache bar. They are the only sleeves that stay when replacing bushings. Quote Link to comment Share on other sites More sharing options...
auxilary Posted February 22, 2002 Share Posted February 22, 2002 Here's a visual of how I got mine out! Once you burn them out, and scrape most of the remaining rubber away, the new ones can be pressed in by hand. Don't forget to add the ES bushing grease (should come with the bushings). Oh, and don't remove that metal "eye" that holds the stock bushings in - it needs to stay in. New bushings are about 30 bucks - I got mine from strictlyz.com (Kyle and Yuichi) http://strictlyz.com/?page=shop/browse&category_id=124&ps_session=ac4a6e5418fd16ee8b842cf9b20adcc6 Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted February 22, 2002 Share Posted February 22, 2002 Nooo.... Don't heat the rubber itself - it will stink you out of the garage! Instead heat the metal surrounding the rubber. When it gets hot enough you'll see little strings of melting rubber begin to squeeze out as the rubber expands. At this point take a socket extension or something and press the bushing right out! Note: this will still smoke some but not nearly as much. If you get small spots of the rubber catching fire blow them out as it will reduce the stink. When it's ready to come out it will come out in one piece easily. Replace with Energy Suspension urethane pieces - I wouldn't reuse the R180 rubber even if you could get it out... Quote Link to comment Share on other sites More sharing options...
DavyZ Posted February 23, 2002 Share Posted February 23, 2002 But Auxilary just enjoys the smell of burning rubber!! Davy Quote Link to comment Share on other sites More sharing options...
z ya Posted February 23, 2002 Author Share Posted February 23, 2002 Thanks guys, I will go for the polys. Does MSA sell the bushings? Part #'s? Quote Link to comment Share on other sites More sharing options...
jeromio Posted February 23, 2002 Share Posted February 23, 2002 Save yerself some bucks: http://www.suspension.com/nissancars.htm Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 23, 2002 Share Posted February 23, 2002 jeromio, that's a great site with excellent prices thanks for the tip. Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted February 24, 2002 Share Posted February 24, 2002 Jeromio, that's where I got my bushings from. They are VERY nice people. If I do another car in the future, I will definitely call them. !M! Quote Link to comment Share on other sites More sharing options...
