deja Posted February 25, 2007 Share Posted February 25, 2007 This may sound like a stupid question but here goes. I understand how to get the transmission angle set up for the differential. But with the motor mounts on and the transmission sitting in the tunnel you can move the rear of the transmission side to side quite a bit. How can I tell if it is sitting in exactly the right place before I bolt down the transmission mount? In other words how do I determine if the transmission is sitting square in the car in relation to the differential? With this engine/tranny sitting offset in the car do I simply measure the distance between the tunnel sides and put the center of the tranny at the center point of the tunnel? Seems like you'd be assuming quite a lot that way. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted February 25, 2007 Share Posted February 25, 2007 Here is one way http://forums.hybridz.org/showthread.php?t=109413 Quote Link to comment Share on other sites More sharing options...
deja Posted February 25, 2007 Author Share Posted February 25, 2007 Pop N Wood said: Here is one way http://forums.hybridz.org/showthread.php?t=109413 Cool, I was thinking there should be a way to do that with lasers. Nice write up. Quote Link to comment Share on other sites More sharing options...
