dimsum Posted March 12, 2007 Author Share Posted March 12, 2007 I just got my Fidanza. My holes go through to the steel ring gear. The bolts off my flywheel are 18mm from the bottom of the bolt head and have 2mm thick lock washers. My clutch won't be in for a while, but it should be a close fit. If I have a clearance problem, I will just file the bolts down just a tad, but I don't think it will be necessary. That's odd. I wonder why mine don't go all the way through to the ring gear. I wonder if Fidanza makes the flywheels both ways. I would be interested to see if WEBEZEEed's flywheel holes don't go all the way through. I ended up using 16 mm bolts to hold the clutch cover snug up against the flywheel. No need for additional washers. Quote Link to comment Share on other sites More sharing options...
