boosting a l28 w/ n42 head
Guest StrikNine
Guest StrikNine
as long as compression is altered is there any other issues with running boost through an n42 cylinder head? (Yes I do understand that cam is different which i've purchased through msa and a stand alone fuel system through megasquirt...)
  • Administrators
You already covered the major issue, compression ratio. Outside of that, the N-42 will work just fine. For what its worth, the N-42 ports are VERY similar to the P-90 Turbo head ports.
My the torque be with you..
