Locked Right rear brake
Guest Mark Musselman
I was wondering if anyone might be able to help with my brake problem. I have a 1971 240. I was driving two weeks ago and the right rear brake locked up. I checked the e-brake but it was, and is not engaged. A friend suggested replacing the wheel cylinder, which I did. The rear wheel is not locked any longer, but there still seems to be quite a bit of drag on the wheel. I remember the brake pedal pulsing with changes in rpm, just before this happend. I have done a V-8 swap and some frame modifications, but have not gotten to the brakes yet. I was going to do a disc conversion this summer, as I don't have the time or money right now.
Does anyone have any suggestions?
It is the brake shoes rubbing, specifically the rear shoe. I did not adjust the pads back in. I will give that a try. Has anyone used the disc brake conversion sets from Arizona Z Car, or Motorsport Auto?
Thank you for the help Pop N Wood
Hey Mark...
Change of subject... did your car get featured last month
on the Stockton Record?
If so...it's very nicely done. You're car is the beige car right?
Also, I thought they were featuring the Sacramento Kings
coache's car (you know, Musselman)!
Problem solved. Thanks for the help!
My Z was featured in the Modesto Bee in December 2006. It is silver. I wish I knew the Kings Coach, I might be able to see them play.
I was right, it was you (although the car looked beige in the newspaper pics)!!
Anyway... nice car... and oh... I'm a Laker fan so good luck seeing
Musselman of the Kings! :) !!!
