ratedZ Posted March 15, 2002 Share Posted March 15, 2002 Guys, I need some advice. I'm looking into getting a set of 225/60/r15's for my new enkies but I have some concens. First off, my Z is lowered you could see a side shot of my Z by following this link http://www.zdriver.com/rides/detailride.php?cat=2&relIdx=11&vehId=69 now I want the tires to tuck nicely in the wheel wells thus the 60 series tires BUT I totally did not take into consideration the fact that the 225's would be wider ultimately making the wheels taller in height as well. This concerns me as I do not want to worry about my wheels rubbing. Sooo...would 225/55's still be too high? or should I go with 50's...again, I don't want to have a big ass gap in the well, I want it to fill out nicely. Thanks all. Quote Link to comment Share on other sites More sharing options...
Mike C Posted March 16, 2002 Share Posted March 16, 2002 Even within the same size tire there can be discrepancies between manufacturers. You can get reall close by taking the tire section 225, multiplying by aspect ratio 60%, double it for both sides of the rim, divide by 25.4 mm/in and add the rim width, 15". 225*.6 +135, 135x2=270, 270/25.4=10.63, 10.63+15~=25.63 You can do this for any tire and get pretty close. The 55 series is ~25.1" tall. Tread width gets wider as the aspect ratio goes down as well even though section width is the same. Quote Link to comment Share on other sites More sharing options...
Guest Rick Johnson Posted March 16, 2002 Share Posted March 16, 2002 The key to getting the tires to sit under the wheel well is wheel offset. That said, with 11mm offset my Yokohama AVS 225 60 15's barely cleared the fender of my 73 240 when it had stock suspension. You should visit the website of the tire mfg and see what he claims the max section width will be for the tire and wheel width you are thinking about. I spent a bunch of money with Tire Rack having them send me down 1 tire at a time to determine if it would fit. Good luck, a bit of trial and error should be anticipated. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted March 16, 2002 Share Posted March 16, 2002 225-60 15's are no problem on a lowered ZX. Check out the pix at the link below. I have Eibach springs that lower about an inch or so. The height is really not the problem. If the fronts are too wide, they will hit the strut. I currently have Yokohama AVS Intermediates on the car. Previously I have had BF Goodrich Comp TA'a, Dunlop D40M2's and Yokohama A520s'. All 225-60 15 on stock "Swastica" wheels. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 16, 2002 Share Posted March 16, 2002 Go to where ever you are getting your tires and ask them to trial mount a set for you. You will know real quick. Quote Link to comment Share on other sites More sharing options...
ratedZ Posted March 18, 2002 Author Share Posted March 18, 2002 Greimann, where did you get your clear turn signals? They look like JDM OEM lights. I made my own with plexi etc. but the one you have on your Z is sooooo much nicer. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted March 18, 2002 Share Posted March 18, 2002 RatedZ, Re:turn signals Those lights were dual purpose driving / fog lights. I took out the high watt bulb for the amber section and put in a regular turn signal bulb. I also had to enlarge the opening in the bumper and fab some brackets. I got them from Pep Boys several years ago, but I don't think they are available any more. Quote Link to comment Share on other sites More sharing options...
Dragonfly Posted March 19, 2002 Share Posted March 19, 2002 Mike did you get the email I sent you with the excel spreadsheet attached? It gives you speeds at different rpm's depending on your tranny, diff, etc. but it also tells you how wide your tires are how tall they are and so on, all you have to do is enter the tire size and it does the math. Dragonfly Quote Link to comment Share on other sites More sharing options...
ratedZ Posted March 22, 2002 Author Share Posted March 22, 2002 Dang that's a good job on the turn signals...I thought they where like the stockers you see on Fairlady's. Good job and I'll take a look at PepBoys and see if they still sell it. Thanks. Hey Miles....no I did not get anything, I've been having problems with my hotmail account being bombarded with junk mail making my account full. Could you re-send it? Thanks for your help! Quote Link to comment Share on other sites More sharing options...
