Alf Posted March 16, 2007 Share Posted March 16, 2007 Hey guys and gals, The task of building a set of headers for the VG30 hot rod is quickly aproaching and depending on what kind of answers I get here could greatly affect the design. My question is this: Is it acceptable to run the O2 sensor on only one bank of the engine? I know stock the VG has joined manifolds and the O2 sensor is directly after they join. The engine I am using is a bone stock NA VG30e from an 84 300ZX. The reason I'm asking is because connecting the pipes is going to require some extra work, but I want to do this the right way. So is it good practice to run the O2 on only one bank of cylinders?? Thanks. Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted March 18, 2007 Share Posted March 18, 2007 Yes, you can run the O2 sensor on just one cylinder but, if you do that your going to be tuning the engine based off information from that one cylinder. If I remember correctly this is how the headers are on the 83 280ZX I used to have. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted March 18, 2007 Administrators Share Posted March 18, 2007 My question is this: Is it acceptable to run the O2 sensor on only one bank of the engine? Mid to late '80's Vette's ran an O2 on one bank only. I suspect most, if not all, V6/V8 GM's in that time period did (I can also vouch for 2.8L V6 Celebrities in that period). Later, with the release of the LT1, GM ran one on EACH bank... BUT, the ECM had the power to individually trim on a bank-to-bank basis. Quote Link to comment Share on other sites More sharing options...
