MY77Z Posted May 29, 2007 Share Posted May 29, 2007 http://store.summitracing.com/partdetail.asp?autofilter=1&part=BRA%2D1653&N=700+4294908331+4294924930+4294840126+4294822066+4294903555+115&autoview=sku i found this, its a high flow pump that rotates both ways, what do you think?? its 3:30AM i need to go to bed but i have to solve this problem first Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted May 29, 2007 Share Posted May 29, 2007 It looks like that water pump will work quite well. It is designed for forward rotation and serpentine pulleys. Go to bed. Quote Link to comment Share on other sites More sharing options...
MY77Z Posted May 29, 2007 Share Posted May 29, 2007 LOOOL ok ok i'll go to bed one last question, 0.625 is the stock Pilot Diameter ?? i wanna make sure before i get this part shipped to kuwait because its a one way trip. P.S. thanks alot bro for your help and you time Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted May 29, 2007 Share Posted May 29, 2007 I am using: 655-1465 From Jegs. It is the March serpentine adjustable alternator bracket. It allows me to run the stock reverse rotation pump from the later model 5.0L motors. I only have crank, alternator, and water pump running. The belt goes from the crank to the alternator back to the crank. The backside fo the belt rotates the water pump. Hope that helps. Goodyear makes a belt around 40" that works. Forget the P/N, just measure with string and then use goodyears online part number system to figure it out: Quote Link to comment Share on other sites More sharing options...
MY77Z Posted May 29, 2007 Share Posted May 29, 2007 i cant use your setup since my alternator is bottom mounted, its almost next to the crank pully. but thanks though for the idea:) Quote Link to comment Share on other sites More sharing options...
74_5.0L_Z Posted May 29, 2007 Share Posted May 29, 2007 That water pump has the same pilot diameter as the stock 5.0L. Therefore you should have no problem in that area. Quote Link to comment Share on other sites More sharing options...
MY77Z Posted May 29, 2007 Share Posted May 29, 2007 thank you in english merci in french gracias in spanish shokran in arabic ALOT FOR YOUR HELP bed time for me, i'll order it tomorow and should receive it here in kuwait in a week or so. Quote Link to comment Share on other sites More sharing options...
MY77Z Posted May 29, 2007 Share Posted May 29, 2007 hi guys, Flow Kooler high flow water pump/ 160degree high flow thermostat/ griffin 24*19 radiator were ordered today should receive them here in kuwait in 5-7 days thanks for all your help guys. Quote Link to comment Share on other sites More sharing options...
MY77Z Posted June 5, 2007 Share Posted June 5, 2007 hi guys, parts received today i took everything out of the car except for one Water pump bolt this thing is stuck, i tryed everything but i cant remove it. i'll be trying again today, and than i'll install all the new stuff but still i have to fabricate mounts for the radiator. Quote Link to comment Share on other sites More sharing options...
Guest Justlikemusic Posted February 2, 2008 Share Posted February 2, 2008 The donor car I'm using is a Jaguar XJ6 with a 302 Windsor... I would like to use it's radiator if possible, but am unsure of the dimensions I have to work with. What is the widest possible radiator that can be fitted to a 280ZX? I dont mind cutting a bit and grinding... radiator hose on the top drivers side, and bottom passenger side. Im going to pull it out today. Quote Link to comment Share on other sites More sharing options...
Silent Posted March 25, 2008 Share Posted March 25, 2008 ed. i do believe i still have a taurus fan laying around if you need it Quote Link to comment Share on other sites More sharing options...
lilredZ Posted March 27, 2008 Share Posted March 27, 2008 click or paste this link...the photo insert didn't work: http://bp0.blogger.com/_lfWLCQRZJiU/RhiScEZ6v0I/AAAAAAAAACc/oE6pGzTBhoc/s1600-h/240zengine20070307.JPG Quote Link to comment Share on other sites More sharing options...
