4znova1 Posted March 23, 2007 Share Posted March 23, 2007 With the following modifications, what boost can i run and what will be estimated horsepower given the mods. Crane cams hi-6 Highly efficient intercooler 2.5-3inch mandrel bent pumbing mandrel bent 2.5" downpipe RRFPR(increase in fp) 3" Exhaust w/ hi flow cat 2mm hks headgasket hks B.o.v 60mm Throttle body.... I am getting the intercooler and dp done right now now and i want to know how much boost to run and what power it will create. I have heard 260 max hp. but also on this forum i have seen 275@15psi Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted March 23, 2007 Administrators Share Posted March 23, 2007 What EFI intake manifold are you using, OE N/A, OE Turbo, aftermarket? Quote Link to comment Share on other sites More sharing options...
CantZme Posted March 24, 2007 Share Posted March 24, 2007 ditch the 2mm hg, it'll just lower compression, which is already REALLY low @ 7.4:1. Off boost response will be horrible and the stock compression can already handle an excess of 20psi(depending on mods)...ditch the HG, it'll only hold u back from your goal of 275 WHP Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted March 24, 2007 Share Posted March 24, 2007 Err.. what engine? Dave Quote Link to comment Share on other sites More sharing options...
4znova1 Posted March 24, 2007 Author Share Posted March 24, 2007 p90 head f54 block turbo intake manifold Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 24, 2007 Share Posted March 24, 2007 So.... are you saying, you've got a completly stock P90/F54 turbo motor/turbo with those mods you wrote above? Its hard to help somebody with an answer to those kind of questions without knowing exactly what you have to begin with.... Paint us a picture of your set up and somebody here can help you, trust me on that one... p90 head f54 block turbo intake manifold Quote Link to comment Share on other sites More sharing options...
