Metal Plate Behind Stub Axle Needed?
S30TRBO
I am using Modern Motorsports CV companion flange with 280Z stub axles. I am also converting to rear disc using Modern Motorsports brackets.
Is the metal backing plate located behind the stub axle needed?
The reason that I am asking is that I am painting the stub axles (minus the shaft;)) and I need to know if those need to be reinstalled when I put new studs in it?
It’s the square bracket that is held in once the studs are in place from behind.
Thanks,
