blueovalz Posted March 27, 2007 Share Posted March 27, 2007 I understand, but when you added spring information, the first thing I think about is "he must be asking about spring clearance and not fender clearance". Lock to lock issues will be in using a taller tire at that width as it may rub on the front lip during a turn if the tires are over 25" tall. My 25.6" tires did rub the very front of the lip (S30)in a turn, but no where else. Quote Link to comment Share on other sites More sharing options...
blueovalz Posted March 27, 2007 Share Posted March 27, 2007 Personally, I only deal with the value for backspacing. I convert the offset to backspacing, and go from there. I've seen some wheels with lip differences that make the backspacing dimension more important than the offset, and for me, backspacing is an absolute value without the calculations (and chances for error) needed when using offset (especially when you're looking for that last 3 or 4 mm next to the strut). Quote Link to comment Share on other sites More sharing options...
280gonboosted Posted March 27, 2007 Author Share Posted March 27, 2007 okay thanks for all your help man. im using an offset calculater. so with the 18x8.5 with a 35mm offset it says i will lose 14mm of backspacing from the strout housing and wheel. with the 18x8.5 with a 15mm i will gain 6mm from my strout housing and wheel. and these numbers are coming from the wheels i currently have. now when i add in my 2inch adapters. which will it affect. will it increase the space between the strout and wheel? or will i lose space between the strout and wheel? Quote Link to comment Share on other sites More sharing options...
80LS1T Posted March 28, 2007 Share Posted March 28, 2007 If you run a 30mm offset you will have to run spacers. I run a 42mm offset and I have to run the Modern Motorsports spacers to use my 17x7's. Someday when I grow up I want to run something like a 10" tire in the rear, sure would be nice for more rubber and I think it would look better! At this point though I just want my car back on the road so new wheels arent't in the budget at this point! Guy Quote Link to comment Share on other sites More sharing options...
JDMFairladyZX Posted March 28, 2007 Share Posted March 28, 2007 I understand, but when you added spring information, the first thing I think about is "he must be asking about spring clearance and not fender clearance". Lock to lock issues will be in using a taller tire at that width as it may rub on the front lip during a turn if the tires are over 25" tall. My 25.6" tires did rub the very front of the lip (S30)in a turn, but no where else. First off my apologizes to the original poster of this thread sorry to thread jack but i dont want to waste making a new thread for a few quick questions for Blue...So If i run 16x10s with a 4"BS (-25.4mm offset and will have the same backspacing as my 15x8s 0offsets which have 205/55/15s, which clear the strut and have no fender or spring rubbing) all around with say 225/50/16 tires I wont have any rub issues up front? Also the wheels will stick out of my fenders a bit wont they? lol thanks again dude, im really excited to get these wheels:-D Quote Link to comment Share on other sites More sharing options...
blueovalz Posted March 28, 2007 Share Posted March 28, 2007 I've already answered this via PM, but for those out there new to wheels and their dimensions (and this is nothing new to most car guys) is the considerations in using backspace and offset in the same context. An advertised wheel width of 10" is the dimension inside the rim lips. The backspacing of a wheel is a dimension for the outside of the rim lips. Thus we are talking about two very different relationships due to the typical lip width of 1/2" per side. Because of this, an advertised 10" wheel with an offset of -1" (-25.4 mm) will have a backspacing of 4.5" rather than 4". I know this may be obvious, but many times I talk to folks about wheels, and they don't consider this when wanting to get that last 1/4" of clearance between the strut and the wheel. So when talking about wheel widths, be sure to consider whether its "advertised", or actual outside-to-outside widths. Quote Link to comment Share on other sites More sharing options...
Drftn280zxt Posted March 29, 2007 Share Posted March 29, 2007 I think the limit of largest size with stock fenders is probably going to be 18x8. Any taller you won't find a tire low profile enough to prevent rubbing, any wider you rub on hard bumps since the wheel well is not wide enough to clear. Quote Link to comment Share on other sites More sharing options...
