Guest Mberglo Posted April 2, 2007 Share Posted April 2, 2007 I'm trying to plan my attack for a 280Z build into a dedicated track car. It looks like I have options as far as front camber adjustment goes. How much negative camber can I expect out of each of the two methods? Is one preferred over the other, or should I expect to install both? Quote Link to comment Share on other sites More sharing options...
johnc Posted April 2, 2007 Share Posted April 2, 2007 Camber plates can get you close to 4 degrees negative and are a definate must-have for a track car. Adjsutable LCAs are more for track width and toe adjustment. They are optional for a track only car. Quote Link to comment Share on other sites More sharing options...
Guest Mberglo Posted April 2, 2007 Share Posted April 2, 2007 Perfect. Thanks. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 2, 2007 Share Posted April 2, 2007 I'm doing a detailed write up on this, should be up in a few hours. John nailed it, but if you want a more detailed writeup check back in a while. Quote Link to comment Share on other sites More sharing options...
