Fuel Damper
24OZ
Guys,
I am running EFI with turbo L28 in my 240Z. I have purchased a nice BOSCH external fuel pump and a SARD FPR and it's dawned on me that the stock system used a fuel damper as well as a FPR.
Will i need to run a Fuel Damper?
My external pump is mounted just opposite the tank.
Thanks folks.
You can just TEE in a length of hose about 12"-15" long after the fuel pump and stick it straight up with a cap on it. The column of air inside the hose will act as a damper.
Might not be needed but better to do it now than go back and add one later if you need it.
