Booztd 3 Posted April 10, 2007 Share Posted April 10, 2007 Guys I'm starting to piece together my oil feed/return setup for the turbo and I'd like to know how you guys are retrofitting AN lines to the oil return setup. I pulled the plug out of the block and just by judging it looks somewhere in the 22-24mm range, but I have no idea if anyone makes a fitting that size to convert to AN -10 Anyone? Quote Link to comment Share on other sites More sharing options...
MrFancypants Posted April 10, 2007 Share Posted April 10, 2007 You talkin oil drain from the turbo back to the block? I cant see you needing anything more than -6 for that. Should all be gravity fed and the feed should be less than -3. - Greg - Quote Link to comment Share on other sites More sharing options...
Booztd 3 Posted April 10, 2007 Author Share Posted April 10, 2007 Precision states I need to run a -10 line drain, so I'm trying to figure out what I need to do for a fitting on the side of the block. I am running a GT42 turbo Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted April 10, 2007 Share Posted April 10, 2007 You can just put fittings into the pan for the turbo oil drain back And, for the block fittings, I just JB welded AN fittings into the OEM drain pipes, as I did here, and on the front turbo This is my head oil drain (top fitting) and my oil pumps external pick up from inside the trap doors in the pan (bottom fitting) Quote Link to comment Share on other sites More sharing options...
Booztd 3 Posted April 10, 2007 Author Share Posted April 10, 2007 I found out that 3/4 NPT will work Quote Link to comment Share on other sites More sharing options...
MrFancypants Posted April 10, 2007 Share Posted April 10, 2007 You can just put fittings into the pan for the turbo oil drain back Be careful with that... if the oil level in the pan is above the drain (as is common), it will not drain. Thats why stock turbos drain to the block. - Greg - Quote Link to comment Share on other sites More sharing options...
J Taylor Posted April 11, 2007 Share Posted April 11, 2007 I took the stock fitting and cut the barb off then got a weld on #10 and had it welded to the end of the factory piece. Works great. JT Quote Link to comment Share on other sites More sharing options...
Booztd 3 Posted April 11, 2007 Author Share Posted April 11, 2007 Hey JT, you are David's neighbor correct? We spoke on the phone the other day and he mentioned his neighbor had a 280 with an rb25/th350....... Quote Link to comment Share on other sites More sharing options...
J Taylor Posted April 12, 2007 Share Posted April 12, 2007 Thats me. He lives pretty much right behind me. Quote Link to comment Share on other sites More sharing options...
