Elmo's New Toys
Elmo said I could use his new toys if I didn't break them.
I will have to retune my carb and engine since they are a little larger and more efficient than my old Rajays.
Turbonetics, TO4B 62-1
4" intake, 2.5" discharge Compressor,
96 A/R, TO4 intake, 3" discharge, P trim Turbine.
These turbos are maxed out at 60 lbs. airflow each but I don't think my engine can generate more than 45 lbs. each, at this time.
I can't wait to hit the road again and see what they'll do.
Hanns
Hi Hanns, Two 62-1's will support a ton of power. I'm not sure how you test a car capable of 90 lb/min airflow, but I'd sure like to try. :D
Just curious, did you consider the Garrett ball bearing turbo's for your application?
Are you going to be able to use your existing manifolds and plumbing?
I bought these turbos because they will fit on my exhaust. However, had to redo the air box inlets and trim some metal from the intake manifold for clearance. I spent 8 hours polishing the turbine housings and now I'm waiting for them to be ceramic coated.
jgkurz ....ball bearing turbos were out of my price range. But these turbos can be upgraded in the future with ball bearings due to the modular nature of these units.
Hanns
