TC Rod washers - How thick?
Based upon a 20" distance from the top strut mounting point to the center of the ball joint, you'll get about .36º of change for each 1/8" of change.
You'll never get too much with washers. The disadvantage would be tire/fender contact in a turn if excessive, and increased steering effort, but that is a small one compared to the improved camber change in the curves/corners.
I don't have any camber curves for the camber/kingpin angles that the Z has, but running in excess of 5º and sometimes up to 7º is not unheard of. I'm running the top end of that range, but this wasn't an issue because the bodywork was matched to the increased wheel base.
