cygnusx1 Posted May 7, 2007 Share Posted May 7, 2007 I was thinking of upgrading the fusible links to Maxi-Fuses. I have seen the upgrades that replace the two sets of links with a single fuse box and some rewiring. However, this might be a simpler, solution. Take four of these: (inline maxi-fuse holders) http://cgi.ebay.com/8-Gauge-MAXI-Fuse-Holder-W-Weather-Cap-50-AMP-Fuse_W0QQitemZ180114022464QQihZ008QQcategoryZ50551QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Add female spade conectors to them and plug them in where the fusible links go, insert appropriate Maxi Fuse and reinstall original white plastic covers. I am not sure if there is enough clearance, but I might try it. It seems quick, cheap and easy to do. -Dave Quote Link to comment Share on other sites More sharing options...
naviathan Posted May 7, 2007 Share Posted May 7, 2007 You still end up with the old dry rotted link box, corroded wiring and poor connections. It's a thought, but I'd rather just replace the whole box. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted May 7, 2007 Author Share Posted May 7, 2007 Well, I assume the link box and wiring is in decent shape before you do this. Of course if the box is crap and the connections are green, you have deeper problems. I should have put in a disclaimer....nah. Survival of the fattest. Quote Link to comment Share on other sites More sharing options...
naviathan Posted May 7, 2007 Share Posted May 7, 2007 Survival of the fattest...lol That's a new one. With 30+ year old wiring though I'd be concerned with everything. My 77 is getting a whole new custom harness. It's gonna rock...lol Quote Link to comment Share on other sites More sharing options...
Teekass Posted August 22, 2007 Share Posted August 22, 2007 I used a Stinger Maxi-Fuse block. http://www.cardomain.com/item/STISFPD4MAXPT It also made it easy to get current for the relay circuit breakers. Quote Link to comment Share on other sites More sharing options...
TONY C Posted August 22, 2007 Share Posted August 22, 2007 I did exactly what you are suggesting. I soldered the connectionsin just for piece of mind sake. no spade connectors. I did mine shortly after I went msII. 1 day I was giving it hell and the link broke and made a few bad arcs and fried a power lead on the msII board. took a while to figure it out. my old fuse links looked good. but they were not making a good connection all the time. sure was alot harder to fix the ms than to replace the fuse links. I have had no problems since. It is a tight squeeze but they will fit under the stock cover. Do It. before it does you. peace Quote Link to comment Share on other sites More sharing options...
