trwebb26 Posted May 12, 2007 Share Posted May 12, 2007 I bought a set of Rota grid wheels from the group buy a few months ago. I'm getting ready to put everything together and (like I was warned) - the hub-centric portion of the wheel hits the front wheel hub (67mm ID wheel vs. 72mm OD hub). Most people are running spacers to "fix" the clearance problem. Because our wheels are lug-centric - do you think there would be a problem with busting out the die grinder and cutting some clearance for the front 2 wheels (to avoid running the spacer)? I'm sure that the center part of the wheel isn't structural - and there will be plenty of "meat" between the lugs and the new - opened up hole. After all - we are only talking about taking off ~3mm of radial clearance. Thanks for your opinions! Quote Link to comment Share on other sites More sharing options...
260zturbo Posted May 12, 2007 Share Posted May 12, 2007 do u have pics of them on your z? i was interested in these awhile back Quote Link to comment Share on other sites More sharing options...
TravRMK Posted May 12, 2007 Share Posted May 12, 2007 I would tend to think that it would be OK. Especially since the material removed is from the center of the wheel, and shouldn't cause any weird ballance problems, like it would if it was further out on the wheel. I would check with a machine shop though, I am sure they wouldn't charge too much just to mill out a little from the center. That IMO would be the way to go. Quote Link to comment Share on other sites More sharing options...
rudypoochris Posted May 13, 2007 Share Posted May 13, 2007 LOL. I manually filed by hand for about 2 hours on the two fronts... Haven't driven it, but I did it. If I remember correctly the grids might clear the 240z front hubs, but I am not positive. I know they don't clear 280z. Quote Link to comment Share on other sites More sharing options...
pete280z Posted May 13, 2007 Share Posted May 13, 2007 Nope - won't fit 240 hubs either. I did a test fit for Wilwoods on a car with 240 hubs. Same problem. Quote Link to comment Share on other sites More sharing options...
