rebuilding turbos questions
Guest HBZ81
Guest HBZ81
So who is makes a rebuild kit for the turbo for the 280zx?
Are all rebuilding kits basically the same? or are there major differenences from let's say a t25 and a t3/04?
What does a kit consist of?
Do I nessecarly have to get someone else's rebuild kit, or can I get the parts for my own for much cheaper at a hardware/home supply store?
i have to agree with pick, if you're uncomfortable in any way doing the rebuild yourself don't even bother. turbos are expensive no matter how you look at them, you could save some money on labor if you're comfortable. the key to it is if you're uneasy with the work don't try it you can end up losing alot more money. there are several mail-in shops that you can send your turbo into as a core and they'll send you a rebuilt one for the price of labor. good luck in your endevour.
Guest HBZ81
the reason im asking this is because i'm thinking about getting into rebuilding turbos. i want to find a way to do it without having to buy other peoples kits
